[GRASS-dev] [GRASS-SVN] r61868 - grass/trunk/locale/po
Maris Nartiss maris.gis at gmail.com
Sun Sep 14 09:44:17 PDT 2014
Auch! Sorry! Seems that KBabel (an outdated editor) has screwed up
something. I like KBabel, but probably it is time to move to Lokalize.
Or is it a bug in gettext, as now on my machine make fails with
"double free error" on Korean grassmods file...
Anyway, I fixed those files manually and commited as r61950 Compiles
fine on my system and UI looks good (or not worse than before in terms
of Latvian language support).
Māris.
2014-09-13 22:02 GMT+03:00 Markus Neteler <neteler at osgeo.org>:
> Hi Maris,
> also this commit is not right:
> po/grasslibs_lv.po:7647: duplicate message definition...
> po/grasslibs_lv.po:3496: ...this is the location of the first definition
> po/grasslibs_lv.po:7746: duplicate message definition...
> po/grasslibs_lv.po:2272: ...this is the location of the first definition
> po/grasslibs_lv.po:7852: duplicate message definition...
> po/grasslibs_lv.po:3240: ...this is the location of the first definition
> po/grasslibs_lv.po:8245: duplicate message definition...
> po/grasslibs_lv.po:2289: ...this is the location of the first definition
> po/grasslibs_lv.po:8565: duplicate message definition...
> po/grasslibs_lv.po:1765: ...this is the location of the first definition
> po/grasslibs_lv.po:8714: duplicate message definition...
> po/grasslibs_lv.po:2624: ...this is the location of the first definition
> po/grasslibs_lv.po:8804: duplicate message definition...
> po/grasslibs_lv.po:3586: ...this is the location of the first definition
> po/grasslibs_lv.po:8818: duplicate message definition...
> po/grasslibs_lv.po:3028: ...this is the location of the first definition
> po/grasslibs_lv.po:8823: duplicate message definition...
> po/grasslibs_lv.po:3032: ...this is the location of the first definition
> po/grasslibs_lv.po:9022: duplicate message definition...
> Which editor do you use?
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
