[GRASS-dev] Some minor TGIS issues in GRASS 7.1
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Sun Sep 14 13:28:26 PDT 2014
Hi again,
First of all, I can second Lucas findings that t.list works fine with "local data". On my Ubuntu laptop and the NC Climae data sample I had no problems with the module.
However, when working on the manual pages for t.remove and t.unegister (for GRASS 7.0) I came across another issue:
Both t.unregister and t.remove do not fully "unregister" maps from the temporal database. Only the "registered_stds" column in "raster_stds_register" is "emptied", while all entities in this table and all entries in "raster_metadata", "raster_spatial_extent", "raster_base", "raster_absolute_time" remain.
So, even after I unregistered all maps of a stds and removed the st(r)ds, the raster map metadata stays in the db, and when I create a new strds and register maps I already had registered earlier I get a warning:
"WARNING: Map is already registered in temporal database. Unable to update raster map 2012_09_precip at climate_1970_2012>. Overwrite flag is not set."
Only t.remove -rf removes everything and properly cleans the temporal db.
Is this intended behavior or a bug?
And, another thing which is unclear to me, should t.remove also unregister all maps associated with the stds or is the user expected to run t.unregister first?
Cheers
Stefan
Von: Blumentrath, Stefan
Gesendet: Donnerstag, 4. September 2014 22:55
An: Luca Delucchi
Betreff: AW: [GRASS-dev] Some minor TGIS issues in GRASS 7.1
Hi Luca,
>We have the same problem in our environment that provide data through NFS, do you also use NFS?
>On my local data I had no problems
I access our server through SSH / VNC, so the problem occures with "local" data in a way. We are using Samba otherwise, but I have not tried from my Windows Laptop...
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140914/dbdd1b4f/attachment.html>
