[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Mon Sep 15 19:13:58 PDT 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by wenzeslaus):
 `r.texture` still has the option named `prefix`, not `basename` (#2136):
  * http://grass.osgeo.org/grass64/manuals/r.texture.html
  * http://grass.osgeo.org/grass70/manuals/r.texture.html
  * http://grass.osgeo.org/grass71/manuals/r.texture.html
 Also the separator of basename and suffix should be resolved (I suppose
 that it is a dot now, needs resolving of discussion in #2136).
 Alternative is to use the approach taken in G7:r.neighbors where no
 `basename`/`prefix` is used. Instead the standard `output` is used with
 `multiple: yes` which simplifies the things in the sense that names must
 be explicitly provided by user. This approach is easier for programmers
 using the module but might be slightly more challenging for users running
 the module manually (but it might be more understandable too since it is
 clear what is the output).
 ''If you think this should be a separate ticket, please copy, paste and
 create.''
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:12>
