[GRASS-dev] [GRASS GIS] #2421: Functions from CDHC lib have no prefix
GRASS GIS trac at osgeo.org
Wed Sep 17 13:37:06 PDT 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  svn-trunk
 Keywords:  cdhclib, api, prefix  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by wenzeslaus):
 Replying to [comment:5 glynn]:
 > Replying to [comment:4 wenzeslaus]:
 > > Even more by the way, does the
 [http://grass.osgeo.org/programming7/shapiro1_8c_source.html#l00032
 following syntax] mean something special?
 > (double).6872
 > No.
 > > I'm pretty sure that it is the same as writing just `.6872`
 > Yes (although a leading zero is preferable, i.e. "0.6872").
 > A floating-point literal with no suffix has type "double". A suffix of
 "f" or "F" makes the type "float". In C99 and later, a suffix of "l" or
 "L" makes the type "long double"
 > It may be that the code was converted from another language using a
 converter which always adds an explicit cast. Or it may have been
 maintained by someone relatively unfamiliar with C who added the cast
 "just to be sure".
 Thanks for the answer, I also wanted to be sure that I understand.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2421#comment:6>
