[GRASS-dev] [GRASS GIS] #2430: v.db.renamecol returns error message "can't find v.db.addcol" and fails
GRASS GIS trac at osgeo.org
Sun Sep 21 10:45:07 PDT 2014
 Reporter:  jbowers   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.5
Component:  Database  |     Version:  6.4.4
 Keywords:            |    Platform:  MSWindows XP
      Cpu:  x86-32    |
 When I try to rename column in a DBF attribute data base using the wxGUI I
 get the error message that v.db.addcol can't be found and the renaming
 process can't be finished.
 Screenshot attached.
 This happens even when I try to rename columns that I added to the
 database using v.db.addcol.
 Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2430>
