[GRASS-dev] lib/python/pygrass/vector/testsuite/test_doctest.py SIGSEGV
Vaclav Petras wenzeslaus at gmail.com
Tue Sep 23 10:44:13 PDT 2014
On Mon, Sep 22, 2014 at 9:53 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Sep 17, 2014 at 9:22 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> Hi,
>> doctest for pygrass.vector are crashing with segmentation fault in
>> Vect_gen_num_db_links() function.
>> Unfortunately, the segfault is not visible in test report, output just
>> ends. The return code of all -11, does this mean something? Do you know how
>> to get the info which is available to system crash handler (which contains
>> "crashed with SIGSEGV", function name and even call stack)?
>> I got the crash report again, now with
> test_doctest.py crashed with SIGSEGV in Vect_line_prune()
> in piemonte_utf32_wgs84_grass7 location.
> Now again segmentation fault in Vect_get_num_db_links(). There were some
details about "target" and "source", not sure if really useful but it would
be great to have a way to obtain this info.
> Again, the info is only in system crash report dialog. It is even not
> visible in the report:
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-22-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/lib/python/pygrass/vector/test_doctests/index.html
> If somebody has a experience with getting these reports or information
> about process segmentation fault, please let me know.
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140923/52a44551/attachment.html>
