[GRASS-dev] Fwd: v.in.lidar return filter
Newcomb, Doug doug_newcomb at fws.gov
Tue Sep 23 11:39:17 PDT 2014
Bringing a side conversation on testing the filtering features  v.in.lidar
and r.in.lidar  into the dev list.
 As I recall, Hamish had something similar working in r.in.xyz with regard
to filtering by z value, but analyzing another variable.
Doug
---------- Forwarded message ----------
Date: Tue, Sep 23, 2014 at 1:30 PM
Subject: Re: [GRASS-dev] v.in.lidar return filter
To: Markus Neteler <neteler at osgeo.org>
Markus,
Here is the result of subtracting the max elevation from the dsm created
from the first returns using v.surt.rst (Height are in feet) . The raster
resolution is 20ft, but I generated the dsm with a 3 ft minimum point
distance.  I would expect the max height to be higher in most cases.
It looks like the 1st returns are being filtered correctly.
Doug
On Tue, Sep 23, 2014 at 12:57 PM, Newcomb, Doug <doug_newcomb at fws.gov>
wrote:
> Working with a test lidar data set from NC mountains ( better quality) .
> Imported 2.6million points using v.in.lidar for all points .  Then went
> back and just imported first returns.  Got a reasonable number , so I'm
> creating a DSM from the 1st returns and will compare it to same resolution
> r.in.lidar for max.
> Filtering by return number and processing for intensity on first, mid, and
> last returns seems to do a good job on contrasting coniferous vs deciduous
> at the top of canopy, midstory, and groundcover look interesting too!
> When I tried to filter  for Z value of elevation 2000-7000 ft, I got
> nodata on the entire layer.  When I changed the Z range to 50 - 200 , I got
> some data with some nodata.
>  I'm guessing that the Z value filter is working on the intensity values
> instead of the Z values.
> Doug
> On Tue, Sep 23, 2014 at 11:33 AM, Markus Neteler <neteler at osgeo.org>
> wrote:
>> Anna just fixed it in trunk.
>> Please try...
>> On Tue, Sep 23, 2014 at 4:51 PM, Newcomb, Doug <doug_newcomb at fws.gov>
>> wrote:
>> > not yet, I was just speculating from looking at the  source.  I will
>> try to
>> > compile from edits to svn this afternoon.   If it works, I'll send a
>> diff.
>> > Doug
>> > On Tue, Sep 23, 2014 at 10:18 AM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >> Did you modify your local file? If yes, could you pls send me a diff
>> >> against SVN or the full file? Then merging is easier...
>> >> thanks
>> >> Markus
>> >> On Tue, Sep 23, 2014 at 2:19 PM, Newcomb, Doug <doug_newcomb at fws.gov>
>> >> wrote:
>> >> > It looks like the same patch needs to be applied to r.in.lidar main.c
>> >> > before
>> >> > line 791. So modifying to the following for both v.in.lidar and
>> >> > r.in.lidar
>> >> > main.c should fix both?
>> >> > if (n_returns == 1) {
>> >> > switch (return_filter) {
>> >> > case LAS_FIRST:
>> >> >     if (return_no == 1)
>> >> > skipme = 0;
>> >> >     break;
>> >> > if (n_returns > 1) {
>> >> > case LAS_FIRST:
>> >> >    if (return_no == 1)
>> >> > skipme = 0;
>> >> >    break;
>> >> > case LAS_LAST:
>> >> >    if (return_no == n_returns)
>> >> > skipme = 0;
>> >> >    break;
>> >> > case LAS_MID:
>> >> >    if (return_no > 1 && return_no < n_returns)
>> >> > skipme = 0;
>> >> >    break;
>> >> > Doug
>> >> > On Tue, Sep 23, 2014 at 8:05 AM, Newcomb, Doug <doug_newcomb at fws.gov
>> >> > wrote:
>> >> >> I don't think it was intentional to drop first and only returns,
>> but if
>> >> >> it
>> >> >> is the first and only return the filter for First and Last Return
>> would
>> >> >> both
>> >> >> match.
>> >> >> Putting another if statement in front along the lines of
>> if(n_returns
>> >> >> 1) set case LAS_FIRST should fix it.
>> >> >> Doug
>> >> >> On Mon, Sep 22, 2014 at 6:54 PM, Anna Petrášová <
>> kratochanna at gmail.com>
>> >> >> wrote:
>> >> >>> Hi,
>> >> >>> I want to import first return points with v.in.lidar, but I get
>> only
>> >> >>> points where the pulse had more then one return. So it gives me
>> trees
>> >> >>> but
>> >> >>> not ground or buildings. I looked in the code and there is an 'if'
>> >> >>> which
>> >> >>> skips points with only 1 return:
>> http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.lidar/main.c#L672
>> >> >>> So the behavior looks intentional but what's the reason?
>> >> >>> Thanks,
>> >> >>> Anna
>> >> >>> _______________________________________________
>> >> >>> grass-dev mailing list
>> >> >>> grass-dev at lists.osgeo.org
>> >> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> >> >> Doug Newcomb
>> >> >> USFWS
>> >> >> Raleigh, NC
>> >> >> 919-856-4520 ext. 14 doug_newcomb at fws.gov
>> >> >> The opinions I express are my own and are not representative of the
>> >> >> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>> >> >> Interior.   Life is too short for undocumented, proprietary data
>> >> >> formats.
>> >> > Doug Newcomb
>> >> > USFWS
>> >> > Raleigh, NC
>> >> > official
>> >> > policy of the U.S.Fish and Wildlife Service or Dept. of the Interior.
>> >> > Life
>> >> > is too short for undocumented, proprietary data formats.
>> > Doug Newcomb
>> > USFWS
>> > Raleigh, NC
>> official
>>  Life
> Doug Newcomb
> USFWS
> Raleigh, NC
> Interior.   Life is too short for undocumented, proprietary data formats.
Doug Newcomb
USFWS
Raleigh, NC
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140923/ddd2ed01/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140923/ddd2ed01/attachment-0001.png>
