[GRASS-dev] r.stats output
Nikos Alexandris nik at nikosalexandris.net
Wed Sep 24 04:14:30 PDT 2014
Paulo van Breugel:
> I am trying to use r.stats to print out a text file with x and y
> coordinates as well as the area (or cell count). However, it seems
> any
> choice is mutually exclusive. If I choose to print the grid
> coordinates and
> to print the area, what I get is the coordinates with the category
> number.
> If I select to print the category labels and area, I only get the
> category
> labels.
> Am I doing something wrong, or is this the intended behaviour? If
> intended,
> would it be an idea to enable printing out any combination of
> selected
> outputs, e.g., coordinates and cell counts, or coordinates and area
> totals?
Hi Paulo.  What coordinates would you expect for area totals?  All of
the coordinates (x,y or -g(rid)) that sum up a aera total?  And how
would you print this in the command line?
Just trying to understand the logic.
Nikos
