[GRASS-dev] [GRASS GIS] #2646: mac OSX - wxpython 3 (64 bit) create histogram of raster map fails to start
GRASS GIS trac at osgeo.org
Sun Apr 5 16:55:49 PDT 2015
start
 Reporter:  epifanio   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  7.1.0
Component:  wxGUI      |     Version:  svn-trunk
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 From the wxpytho gui -> Analyze map -> create histogram of raster map
 the widget doesn't load, the following log is printed in the shell (full
 debug enabled) :
 GRASS 7.1.svn (NAD83_UTM_18N):~ > GUI D3/5: BaseToolbar.OnTool(): id = 179
 GUI D1/5: Map.__init__(): None
 D1/5: grass.script.core.start_command(): g.tempfile -d pid=90304
 D1/5: G_set_program_name(): g.tempfile
 D2/5: G_file_name(): path = /Users/epi/grass7data/NAD83_UTM_18N/PERMANENT
 /Users/epi/grass7data/NAD83_UTM_18N/PERMANENT/.tmp/epimac.local/90304.0
 D1/5: grass.script.core.start_command(): g.gisenv -n
 D1/5: G_set_program_name(): g.gisenv
 D2/5: G_option_to_separator(): key = separator -> sep = '
 GUI D1/5: gcmd.RunCommand(): g.proj -p
 D1/5: grass.script.core.start_command(): g.proj -p
 GUI D1/5: gcmd.RunCommand(): get return code 0 (0.043165 sec)
 GUI D3/5: gcmd.RunCommand(): return stdout
 '-PROJ_INFO-------------------------------------------------
 name       : Universal Transverse Mercator
 proj       : utm
 datum      : nad83
 ellps      : grs80
 zone       : 18
 no_defs    : defined
 -PROJ_UNITS------------------------------------------------
 unit       : meter
 units      : meters
 meters     : 1
   File "/usr/local/grass-7.1.svn/gui/wxpython/mapdisp/frame.py", line
 1104, in OnHistogramPyPlot
     win = HistogramPlotFrame(parent = self, rasterList = raster)
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxplot/histogram.py", line
 39, in __init__
     BasePlotFrame.__init__(self, parent, size = size, **kwargs)
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxplot/base.py", line 88, in
 __init__
     self.client = plot.PlotCanvas(self)
   File
 "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7
 /site-packages/wx-3.0-osx_cocoa/wx/lib/plot.py", line 598, in __init__
     self.HandCursor = wx.Cursor(Hand.GetImage())
   File
 /site-packages/wx-3.0-osx_cocoa/wx/_gdi.py", line 1502, in __init__
     _gdi_.Cursor_swiginit(self,_gdi_.new_Cursor(*args, **kwargs))
 TypeError: Required argument 'type' (pos 2) not found
Ticket URL: <https://trac.osgeo.org/grass/ticket/2646>
