[GRASS-dev] raster.dll problem
Vaclav Petras wenzeslaus at gmail.com
Wed Apr 22 12:59:21 PDT 2015
Unfortunately, raster.dll from ERDAS problem is still around. This happens
in the Windows system command line on some computer when using v.in.proj
using the dialog:
C:\Users\john> ***ERROR NUMBER 2338 IN FUNCTION
edll_InstanceOpenByClassName***
 >>>DLL Open failed for C:/Program Files/Intergraph/ERDAS IMAGINE
2014/usr/lib/W
in32Release/FileFilters/raster.dll<<
 ***ERROR NUMBER 162 IN FUNCTION edll_Open***
 >>>Could not load DLL C:\Program Files\Intergraph\ERDAS IMAGINE
2014\usr\lib\Wi
n32Release\FileFilters\raster.dll: The module was not found.<<
 ***ERROR NUMBER 2338 IN FUNCTION edll_InstanceOpenByClassName***
2014/usr/lib/W
2014\usr\lib\Wi
Then GUI Command console reports a lot of errors when running g.gisenv -n.
Previous tests using Dependency Walker revealed nothing. Some things
suggested that it might be related to Browse button in wxPython but it's
unclear. More investigation needed.
Interestingly, the only things I was able to find about ERROR NUMBER ... IN
FUNCTION edll_Open are:
http://forums.esri.com/Thread.asp?c=93&f=38&t=132335&g=1
http://support.esri.com/ja/knowledgebase/techarticles/detail/16623
https://groups.yahoo.com/neo/groups/Arcview/conversations/messages/9840
I even don't know what to put to the WinGRASS errors page. Uninstall ERDAS?
I was not able to check if this would help.
http://grasswiki.osgeo.org/wiki/WinGRASS_errors
On Sat, Jan 24, 2015 at 1:25 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Sat, Jan 24, 2015 at 12:56 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
>> On Sat, Jan 24, 2015 at 6:34 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> > Hi,
>> > one student has problems running grass7 beta4. She keeps getting:
>> > Could not load DLL C:\Program Files\Intergraph\ERDAS Imagine
>> > 2014\usr\lib\Win32Release\FileFilters\raster.dll: The module was not
>> found.
>> > I couldn't find anything helpful. She gets this when running g.region,
>> but I
>> > am not sure if that's the only case. Any idea?
>> She may try to disentangle the DLL dependencies (e.g. with "Dependency
>> Walker" - only free as in free lunch, not software libero):
>> http://www.dependencywalker.com.
>> Perhaps then you see the issue.
>> Markus
> Thanks to you both for this suggestion, I will let you know if we find
> anything useful.
> Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150422/443cb5c1/attachment.html>
