[GRASS-dev] Limit in number of "variables" for r.mapcalc?
Nikos Alexandris nik at nikosalexandris.net
Fri Apr 24 14:51:30 PDT 2015
Hi devs,
is there a limit in the number of "variables" that r.mapcalc accepts
within from 'eval'? If yes, how big is it?
I am trying to feed r.mapcalc's eval with a fairly large number of pixel
modifiers and, given that the final expression is a valid one, the
execution ends with:
    debug=1 ended with error
    Process ended with non-zero return code -11. See errors in the (error)
    output.
Thank you, Nikos
