[GRASS-dev] [GRASS GIS] #2665: d.* modules not working from python or bash scripts (GRASS 7.0, Linux / Windows7)
GRASS GIS trac at osgeo.org
Wed Apr 29 10:17:55 PDT 2015
Windows7)
  Reporter:  santipardo  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.0.1
 Component:  Display     |    Version:  7.0.0
Resolution:              |   Keywords:  d.mon, d.vect, d.rast, python,
                         |  script, bash
       CPU:  x86-64      |   Platform:  All
Comment (by santipardo):
 This is weird. The commands are written to the cmd file of the monitor
 (e.g.: .tmp/24518.0.cmd):
 d.rast map="M01relief" bgcolor="white"
 d.vect map="M03PTEtramos" layer="1" display="shape"
 type="point,line,boundary,area,face" color="black"
 fill_color="200:200:200" width=2 width_scale=1 icon="basic/x" size=5
 label_layer="1" label_color="red" label_bgcolor="none" label_bcolor="none"
 label_size=8 xref="left" yref="center"
 But I do not get the layers shown until I manually open the file (in a
 text editor) and save it. Using some python code to open, edit and save
 the trick doesn't work:
 with open(rutamon, 'a') as comandos:
         comandos.write('d.redraw')
         comandos.close()
 Here I open the file in append mode, and add a line for 'd.redraw'. But it
 doesn't work, I have to open and save manually the file...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2665#comment:1>
