[GRASS-dev] C syntax and the use of underscore ('_')
Rob Parsons jrobparsons at gmail.com
Sun Aug 2 09:42:16 PDT 2015
In r.univar_main.c, there are a number of string assignments similar to
this:
param.percentile->description =
    _("Percentile to calculate (requires extended statistics flag)");
I am not familiar with the '_' syntax as it is being used here before the
opening '('.
The Eclipse editor complains about syntax.
Anyone know what is happening here?
Regards,
Rob Parsons
Raleigh NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150802/e635d455/attachment.html>
