[GRASS-dev] support for raster time series in rgrass7?
Veronica Andreo veroandreo at gmail.com
Tue Aug 18 06:19:20 PDT 2015
Hi Soeren,
2015-08-18 10:07 GMT-03:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi Veronica,
> first note: the attached file is a gzip archive, the suffix is wrong.
ops! Yes, you are right... write.tgrass creates gzip files, my mistake, I'm
sorry...
> However, this seems to be a bug in t.rast.import, since the file names
> in the tar archive are listed with a "./" in the path.
> I will try to fix this issue.
Thanks a lot!
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150818/83f64851/attachment.html>
