[GRASS-dev] grass-addons and nested module libraries
Matej Krejci matejkrejci at gmail.com
Fri Aug 21 02:31:00 PDT 2015
Dear Pietro, devs,
2015-08-17 12:57 GMT+02:00 Pietro <peter.zamb na gmail.com>:
> Dear devs,
> I've noticed that r.green module is installing his libraries in the wrong
> place:
> $ # rm -r $GRASS_ADDON_BASE
> $ g.extension extension=r.green
> Fetching <r.green> from GRASS GIS Addons repository (be patient)...
> Compiling...
> Installing...
> Updating addons metadata file...
> ERROR: Unable to read manual page: [Errno 2] No such file or directory:
>        '/home/pietro/.grass7/addons/docs/html/r.green.html'
> that generate a tree directory like:
> $ tree $GRASS_ADDON_BASE
> ├── bin
> ├── docs
> │   ├── html
> │   │   ├── grassdocs.css
> │   │   ├── r.green.biomassfor.co2.html
> │   ├── man
> │   │   └── man1
> │   │       ├── r.green.biomassfor.co2.1
> │   │       ├── r.green.biomassfor.economic.1
> │   └── rest
> ├── etc
> ├── libgreen
> │   ├── checkparameter.py
> ├── libhydro
> │   ├── basin.py
> ├── modules.xml
> └── scripts
> I would like that both the directories: libgreen and libhydro are
> installed inside  $GRASS_ADDON_BASE/etc/r.green:
> ├── bin
> ├── docs
> │   ├── html
> │   ├── man
> │   │   └── man1
> │   └── rest
> ├── etc
> │   └── r.green
> │       ├── libgreen
> │       │   ├── checkparameter.py
> │       └──libhydro
> │           ├── basin.py
> ├── modules.xml
> └── scripts
> I think the problem is due that when in the Makefile I create the
> ETCDIR the LIBGREENDIR does not exist yet:
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.green/libgreen/Makefile#L18
> Therefore I've tried adding to the Makefile something like:
> $ svn diff libgreen/Makefile
> Index: libgreen/Makefile
> --- libgreen/Makefile   (revision 65945)
> +++ libgreen/Makefile   (working copy)
> @@ -15,6 +15,9 @@
>  default: $(PYFILES) $(PYCFILES) $(ETCDIR)/__init__.py
> $(ETCDIR)/__init__.pyc
> +$(LIBGREENDIR):
> +       $(MKDIR) $@
>  $(ETCDIR):
>         $(MKDIR) $@
> But it continue to install libgreen and libhydro in the
> $GRASS_ADDONS_BASE root...
> NOTE: if I compile the module with: make MODULE_TOPDIR=$GISBASE both
> the directories are created in the correct place:
> $ ls -l $GISBASE/etc/r.green
> total 8.0K
> drwxr-xr-x 2 pietro pietro 4.0K Aug 17 12:52 libgreen/
> drwxr-xr-x 2 pietro pietro 4.0K Aug 17 12:52 libhydro/
> Why?
> Someone has an idea on how I could/should fix this?
> Pietro
> grass-dev mailing list
> grass-dev na lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
I have exactly the same problem(described bellow) with installation
wx.metadata from addons. Have you figured out this issue?
1)Local installation works well:
matt na matt-pc:~/addons/grass7/gui/wxpython/wx.metadata$ make
MODULE_TOPDIR=$HOME/grass_trunk & make MODULE_TOPDIR=$HOME/grass_trunk
install
...no errors
matt na matt-pc:~/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/wx.metadata$
tree
├── config
│   ├── connections_resources.xml
│   ├── default-sample.cfg
│   ├── init_md.txt
│   ├── keywordConcepts.txt
│   ├── keywordGroups.txt
│   ├── keywordThemes.txt
│   ├── record_metadata_dc.html
│   ├── service_metadata.html
│   ├── xml_highlight.html
│   └── xml_render.html
├── mdlib
│   ├── cswlib.py
│   ├── cswlib.pyc
│   ├── cswutil.py
│   ├── cswutil.pyc
│   ├── mdeditorfactory.py
│   ├── mdeditorfactory.pyc
│   ├── mdgrass.py
│   ├── mdgrass.pyc
│   ├── mdjinjaparser.py
│   ├── mdjinjaparser.pyc
│   ├── mdpdffactory.py
│   ├── mdpdffactory.pyc
│   ├── mdpdftheme.py
│   ├── mdpdftheme.pyc
│   ├── mdutil.py
│   └── mdutil.pyc
└── profiles
    ├── basicProfile.xml
    ├── inspireProfile.xml
    └── temporalProfile.xml
...everything is correctly placed
2) Installation from addons doesn't work correctly
GRASS 7.1.svn (cr-wgs84):~ > g.extension wx.metadata
...successful
matt na matt-pc:~/.grass7/addons$ tree
├── bin
├── docs
│   ├── html
│   │   ├── db.csw.admin.html
│   │   ├── db.csw.harvest.html
│   │   ├── db.csw.run.html
│   │   ├── g.gui.cswbrowser.html
│   │   ├── g.gui.metadata.html
│   │   ├── r.info.iso.html
│   │   ├── t.info.iso.html
│   │   └── v.info.iso.html
│   ├── man
│   │   └── man1
│   │       ├── db.csw.admin.1
│   │       ├── db.csw.harvest.1
│   │       ├── db.csw.run.1
│   │       ├── g.gui.cswbrowser.1
│   │       ├── g.gui.metadata.1
│   │       ├── r.info.iso.1
│   │       ├── t.info.iso.1
│   │       └── v.info.iso.1
│   └── rest
├── etc
├── mdlib
│   ├── cswlib.py
│   ├── cswlib.pyc
│   ├── cswutil.py
│   ├── cswutil.pyc
│   ├── mdgrass.py
│   ├── mdgrass.pyc
│   ├── mdpdftheme.py
│   ├── mdutil.py
│   └── mdutil.pyc
├── modules.xml
└── scripts
    ├── db.csw.admin
    ├── db.csw.harvest
    ├── db.csw.run
    ├── g.gui.metadata
    ├── r.info.iso
    ├── t.info.iso
    └── v.info.iso
failed:
   - dir *mdlib* is not placed in *etc*
   - dir *config* is missing
   - dir *profiles*  is missing
thanks for any advice
Matej
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150821/cab17d57/attachment-0001.html>
