[GRASS-dev] g.gui.metadata and wxgui addons in GRASS 7.1
Matej Krejci matejkrejci at gmail.com
Fri Aug 21 05:42:54 PDT 2015
Dear Stefan,
Thanks for bug report. I have done few changes(r65990) which should help
but the installation from add-ons still doesn't work properly[1].
2015-08-20 14:41 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath na nina.no>:
> Hi,
> I just tried to install g.gui.metadata addon with limited success.
> No AddOn appears under wxGUI when I run g.extension from the GUI (while
> e.g. raster addons do show up). Is this probably do to the path in the
> AddOn repo (which starts with gui and not wxGUI). All other tree elements
> in g.extension are equal to folder names in the repository…
> So, I finally compiled g.gui.extension from source after installing the
> dependencies.
> Now, g.gui.metadata is available, but does not start:
> Traceback (most recent call last):
>   File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata",
> line 1246, in <module>
>     main()
> line 1240, in main
>     MAINFRAME = MdMainFrame()
> line 88, in __init__
>     self.onInitEditor()
> line 724, in onInitEditor
>     self.MdDataCatalogPanelLeft =
> MdDataCatalog(self.leftPanel)
> line 836, in __init__
>     self.InitTreeItems()
> line 860, in InitTreeItems
>     self.initTemporalTree(location=location,
> mapset=self.mapset)
> line 923, in initTemporalTree
>     if self.itemExists(ml[2], varmapset) == False:
>   File
> "/usr/local/grass-7.1.svn/gui/wxpython/lmgr/datacatalog.py",
> line 213, in itemExists
>     item, cookie = self.GetFirstChild(root)
>   File "/usr/lib/python2.7/dist-
> packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 5409, in
> GetFirstChild
>     return _controls_.TreeCtrl_GetFirstChild(*args,
> **kwargs)
> ValueError: invalid null reference in method
> 'TreeCtrl_GetFirstChild', expected argument 2 of type
> 'wxTreeItemId const &'
Best
Matej
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-August/076034.html
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150821/20e454d9/attachment.html>
