[GRASS-dev] New Mac binaries uploaded
Michael Barton Michael.Barton at asu.edu
Mon Aug 24 08:31:33 PDT 2015
Anna,
These work for me and at least some of my students here. So we need to find out why they don't work for you. I'm teaching spatial tech this fall and want to make sure others don't run into trouble. 7.0.1 was a completely fresh checkout and 7.1 was compiled after a make distclean.
Do you have any idea what causes this error? Did you install a new gdal? I compiled with William's most current version. I am still using stock Mac Python and wx version 2.8.12. Have you installed anything newer in the testing I saw on the list?
Michael Barton
School of Human Evolution &Social Change
Center for Social Dynamics & Complexity
Arizona State University
...Sent from my iPad
On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
Hi Michael,
sorry to report but the new binaries (70 and 71) don't work, the gui doesn't open with this error. I already saw this error multiple times and it might be enough just to make distclean and recompile or fresh svn checkout.
GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent call last):
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 140, in <module>
    sys.exit(main())
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 132, in main
    app = GMApp(workspaceFile)
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 46, in __init__
    wx.App.__init__(self, False)
  File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
    self._BootstrapApp()
  File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 79, in OnInit
    from lmgr.frame import GMFrame
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
    from lmgr.layertree        import LayerTree, LMIcons
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
    from mapdisp.frame        import MapFrame
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 34, in <module>
    from vdigit.toolbars    import VDigitToolbar
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
    from iclass.digit       import IClassVDigit
  File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
    from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't have GDAL 1.10, but 1.11.
dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
  Referenced from: /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
  Reason: image not found
Trace/BPT trap: 5
If you don't have time to look at it now, could you please post the GRASS 7.0.0 binary which I believe worked.
Thank you,
Anna
On Wed, Aug 12, 2015 at 6:29 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I just uploaded new binaries for:
GRASS 6.4.6 stable
GRASS 7.0.1 stable
GRASS 7.1 development
These all run on current versions of Mac OS X 10.9 through 10.10.4
Note that I’m using a newish version of GDAL complete (1.11 dated May 2015)
I’ve heard that there may be problems compiling GRASS on OS X 10.11. I don’t know if these binaries will run under the new OS or not. However, this new OS version is not yet released. So problems may be worked out by the time it is finalized.
For now, enjoy GRASS.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
voice:  480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130<tel:480-965-8130>/727-9746 (CSDC)
fax: 480-965-7671<tel:480-965-7671> (SHESC),  480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150824/f401f2f4/attachment-0001.html>
