[GRASS-dev] New Mac binaries uploaded
Newcomb, Doug doug_newcomb at fws.gov
Tue Aug 25 06:15:42 PDT 2015
The free tools of LASlib are licensed under the LGPL and cover LAS versions
1.0-1.3 .  I don't think LAS 1.4 is covered yet ( I could be wrong) .  LAS
format up to 1.3  is limited to 4.2 billion points per file ( 32 bit
integer) LAS 1.4 uses a 64 bit integer identifier.
LASlib is also maintained by a single developer.
The principle author of Liblas ( Howard Butler)  has moved on with others
to develop the pdal software, http://www.pdal.io/.  I've cc'ed Howard in
case he would like to weigh in on the technical differences.
Doug
On Mon, Aug 24, 2015 at 11:45 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> That would be wonderful. I sort of got that impression too. But will the
> GRASS lidar tools be able to use LASlib instead of Liblas?
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> > On Aug 24, 2015, at 8:40 PM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > I looked at LAS this spring.  From what I found, libLAS is superceded by
> LASlib, found in LAStools.  laslib and some of the tools are still
> opensource, but other tools are not.
> > Laslib does not have a configure, it's a simple makefile that needs a
> little tweaking for OS X.  And there appears to be no dependence on BOOST
> or Geotiff, or anything else.
> > For laslib, all I needed to do was edit laslib/src/makefile and change
> these lines:
> > COPTS     = -Os -Wall -Wno-deprecated -DNDEBUG -DUNORDERED -arch x86_64
> -isysroot /Developer/SDKs/MacOSX10.7.sdk
> > COMPILER  = clang++
> > And in the liblas.a target, add a line after the cp line (tha's a tab at
> the start):
> >       ranlib ../lib/$@
> > Also delete the precompiled Windows lib in laslib/lib.
> > You should be able to use the library right from the source, it's static
> so it will be built into GRASS without needing a copy of the laslib.  For
> GRASS configuration, the library will be in that lib folder and includes in
> the laslib/inc folder.
> > On Aug 24, 2015, at 3:47 PM, Michael Barton <michael.barton at asu.edu>
> wrote:
> >> For LASlib compliing, I managed to get past the GEOTIFF problem with
> the following:
> >> cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES="i386;x86_64” \
> >> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” \
> >> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
> >> -D
> GEOTIFF_INCLUDE_DIR=/Library/Frameworks/UnixImageIO.framework/unix/include \
> >> -D
> GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib
> >> But now cmake is complaining about the CMAKE_OSX_ARCHITECTURES flag. I
> don’t know if this harkens back to the similar problem with boost or if
> this is new. I’ve tried both i386 and x86_64 individually and it still
> won’t compile.
> >> Michael
> >> C. Michael Barton
> >>> On Aug 24, 2015, at 1:30 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
> >>> I’ve started trying to recompile liblas using the notes from last time
> (I think William provided considerable help on this). So far it is not
> working.
> >>> 1 Recompiling boost 1.5.4
> >>> cd /Users/Shared/grass_dev/boost_1_54_0 ##note that I did not do
> anything to clean up my original compilation. Should I? How with C++?
> >>> edit
> /Users/Shared/grass_dev/boost_1_54_0/tools/build/v2/tools/darwin.jam to
> delete -gdwarf-2  ## already done
> >>> export CXXFLAGS=-stdlib=libstdc++
> >>> ./bootstrap.sh
> --prefix=/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow
> --without-libraries=python
> >>> ## this worked several years ago but now fails. I DO have the OS X
> 10.7 SDK FWIW
> >>> ./bjam variant=release link=static --without-mpi -j4
> macosx-version=10.7 macosx-version-min=10.7 architecture=x86
> address-model=32_64 install
> >>> ## So I tried without specifying the minimum OS and address model.
> This compiled but could be incorrect
> >>> ./bjam variant=release link=static --without-mpi -j4 install
> >>> ## This was in my notes but does not seem needed
> >>> Need to manually delete the comma at the end of the list on line 117
> of /boost-snow/include/boost/interprocess/errors.hpp
> >>> 3. Then follow instructions at:
> http://www.liblas.org/compilation.html#using-xcode-on-os-x for standard
> install (not xcode)
> >>> from libLAS folder...
> >>> cd to liblas source folder
> >>> mkdir makefiles
> >>> cd makefiles
> >>> export
> BOOST_ROOT="/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow"
> >>> cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES="i386;x86_64" -D
> CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk" ../
> >>> ## fails because it can’t find geotiff libraries. But it does find
> geotiff libraries. So that’s weird. Also cannot find laszip. I can’t tell
> if this is required or optional. I didn’t need it before.
> >>> ## here is the error…
> >>> Searching for LASzip 2.0.1+ library
> >>> -- Could NOT find LASzip (missing:  LASZIP_LIBRARY LASZIP_INCLUDE_DIR)
> (Required is at least version "2.0.1")
> >>> -- Searching for GDAL 1.7.0+ library
> >>> -- Found acceptable GDAL version 1.11.2
> >>> -- Searching for GeoTIFF 1.2.5+ library
> >>> -- Found GeoTIFF version: 1.4.0
> >>> -- Could NOT find GeoTIFF (missing:  GEOTIFF_LIBRARY) (Required is at
> least version "1.2.5")
> >>> CMake Error at CMakeLists.txt:262 (message):
> >>>  GDAL support requires GeoTIFF library which was not found
> >>> So this is where I’m stuck currently. Any suggestions would be
> appreciated.
> >>> Michael
> >>> C. Michael Barton
> >>>> On Aug 24, 2015, at 10:50 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> >>>> On Mon, Aug 24, 2015 at 1:40 PM, Michael Barton <
> Michael.Barton at asu.edu> wrote:
> >>>> If I am understanding the compiling instructions correctly, it
> installs binaries of the open source LAStools and Liblas too. But I may
> misunderstand. The GRASS LAS tool set needs both I believe.
> >>>> GRASS GIS is fine just with the library. The expected library libLAS (
> http://www.liblas.org/) as far as I know.
> >>>> I'm not sure what "open source LAStools" would be, some of the
> LAStools are perhaps open source but some are definitively not. In any
> case, GRASS GIS does not depend on any tools -- the ones related to libLAS
> nor the ones related LASlib.
> >>>> Vaclav
> >>>> Michael
> >>>> C. Michael Barton
> >>>>> On Aug 24, 2015, at 10:29 AM, Newcomb, Doug <doug_newcomb at fws.gov>
> wrote:
> >>>>> Liblas or LASTools?
> >>>>> Doug
> >>>>> On Mon, Aug 24, 2015 at 1:08 PM, Michael Barton <
> >>>>> Yes. The LAS tools are compiled for GDAL 1.10. They were a royal
> pain to compile. The instructions to the newest LAStools source code makes
> it sound like it is much easier now. Does anyone have any experience with
> the current version? I was going to try it but wanted to make sure I had a
> GRASS version out with at least a clunky working version before risking it.
> >>>>> Michael
> >>>>> C. Michael Barton
> >>>>>> On Aug 24, 2015, at 9:56 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> >>>>>> Michael, you may need to recompile your las tools to use the
> current GDAL, this is separate from GRASS compilation.
> >>>>>> On Aug 24, 2015, at 10:31 AM, Michael Barton <
> >>>>>>> Anna,
> >>>>>>> These work for me and at least some of my students here. So we
> need to find out why they don't work for you. I'm teaching spatial tech
> this fall and want to make sure others don't run into trouble. 7.0.1 was a
> completely fresh checkout and 7.1 was compiled after a make distclean.
> >>>>>>> Do you have any idea what causes this error? Did you install a new
> gdal? I compiled with William's most current version. I am still using
> stock Mac Python and wx version 2.8.12. Have you installed anything newer
> in the testing I saw on the list?
> >>>>>>> Michael Barton
> >>>>>>> School of Human Evolution &Social Change
> >>>>>>> ...Sent from my iPad
> >>>>>>> On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> >>>>>>>> Hi Michael,
> >>>>>>>> sorry to report but the new binaries (70 and 71) don't work, the
> gui doesn't open with this error. I already saw this error multiple times
> and it might be enough just to make distclean and recompile or fresh svn
> checkout.
> >>>>>>>> GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most
> recent call last):
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line
> 140, in <module>
> >>>>>>>>   sys.exit(main())
> >>>>>>>> File
> 132, in main
> >>>>>>>>   app = GMApp(workspaceFile)
> >>>>>>>> File
> 46, in __init__
> >>>>>>>>   wx.App.__init__(self, False)
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line
> 7981, in __init__
> >>>>>>>>   self._BootstrapApp()
> >>>>>>>> File
> 7555, in _BootstrapApp
> >>>>>>>>   return _core_.PyApp__BootstrapApp(*args, **kwargs)
> >>>>>>>> File
> 79, in OnInit
> >>>>>>>>   from lmgr.frame import GMFrame
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> line 50, in <module>
> >>>>>>>>   from lmgr.layertree        import LayerTree, LMIcons
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
> line 37, in <module>
> >>>>>>>>   from mapdisp.frame        import MapFrame
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
> line 34, in <module>
> >>>>>>>>   from vdigit.toolbars    import VDigitToolbar
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
> line 30, in <module>
> >>>>>>>>   from iclass.digit       import IClassVDigit
> >>>>>>>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
> line 23, in <module>
> >>>>>>>>   from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
> >>>>>>>> ImportError: cannot import name TYPE_AREA
> >>>>>>>> Also, v.in.lidar or las2las (anything using liblas) doesn't work.
> I don't have GDAL 1.10, but 1.11.
> >>>>>>>> dyld: Library not loaded:
> /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
> >>>>>>>> Referenced from:
> /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
> >>>>>>>> Reason: image not found
> >>>>>>>> Trace/BPT trap: 5
> >>>>>>>> If you don't have time to look at it now, could you please post
> the GRASS 7.0.0 binary which I believe worked.
> >>>>>>>> Thank you,
> >>>>>>>> Anna
> >>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >>>>>> http://www.kyngchaos.com/
> >>>>>> First Pogril: Why is life like sticking your head in a bucket
> filled with hyena offal?
> >>>>>> Second Pogril: I don't know.  Why IS life like sticking your head
> in a bucket filled with hyena offal?
> >>>>>> First Pogril: I don't know either.  Wretched, isn't it?
> >>>>>> -HitchHiker's Guide to the Galaxy
> >>>>> _______________________________________________
> >>>>> grass-dev mailing list
> >>>>> grass-dev at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> >>>>> Doug Newcomb
> >>>>> USFWS
> >>>>> Raleigh, NC
> >>>>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> >>>>> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> Interior.   Life is too short for undocumented, proprietary data formats.
> > "Time is an illusion - lunchtime doubly so."
> > - Ford Prefect
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150825/2de7b184/attachment-0001.html>
