[GRASS-dev] [GRASS GIS] #2726: v.unpack fails when importing into a cartesian CRS
GRASS GIS trac at osgeo.org
Wed Aug 26 05:38:30 PDT 2015
 Reporter:  micha    |      Owner:  grass-dev@…
     Type:  defect   |     Status:  new
 Priority:  normal   |  Milestone:  7.0.2
Component:  Default  |    Version:  7.0.1
 Keywords:           |        CPU:  Unspecified
 Platform:  Linux    |
 WHen using v.pack/v.unpack to move vector maps to a different machine, and
 the LOCATION is a cartesian, unprojected, X-Y coordinate system , the
 operation fails with:
 GRASS 7.0.1 (XY):~ > v.unpack ~/Desktop/Allkavels.pack
   File "/usr/lib/grass70/scripts/v.unpack", line 211, in <module>
     sys.exit(main())
   File "/usr/lib/grass70/scripts/v.unpack", line 114, in main
     filename_b=loc_proj, proj=True):
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 895, in
 compare_key_value_text_files
     checkunits=units)
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 822, in
 _text_to_key_value_dict
     text = open(filename, "r").readlines()
 IOError: [Errno 2] No such file or directory:
 '/home/micha/GIS/grass/XY/test/.tmp/work-vm/23766.0/PROJ_INFO'
 The PROJ_INFO file ideed does not exist in an unprojected LOCATION.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2726>
