[GRASS-dev] [GRASS GIS] #2729: Missing Vect_new_map_struct
GRASS GIS trac at osgeo.org
Thu Aug 27 06:30:37 PDT 2015
  Reporter:  rblazek      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  All
Changes (by huhabla):
 * milestone:  7.0.1 => 7.1.0
Comment:
 Patch applied in r66048. I did not modified the patch to use G_malloc(),
 since the error message would be generic then. However, if this is not of
 importance, then we should use G_malloc() and remove the function specific
 G_fatal_error() call.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2729#comment:2>
