[GRASS-dev] Vect_new_map_struct
Sören Gebbert soerengebbert at googlemail.com
Thu Aug 27 06:45:07 PDT 2015
Hi Radim,
your patch was applied in r66048 as is. I think to make sure that the
Map_info substructures are correctly de-allocated, all de-allocation
events in the vector lib must be found and analysed, if the
corresponding pointer are set to NULL. Then you can implement a
recursive de-allocation of the Map_info structure in
Vect_destroy_map_struct().
in r66046 i have implemented point,line,boundary and area to WKT and
WKB converter, based on the GRASS GEOS support in
"lib/vector/Vlib/geos.c". This may be useful in the QGIS GRASS vector
iterator?
Please have a look at:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/geos_to_wktb.c?rev=66046
Best regards
Soeren
2015-08-26 19:37 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
> Hi,
> I have created new issue https://trac.osgeo.org/grass/ticket/2729
> requesting to add Vect_new_map_struct, patch is supplied.
> Radim
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
