[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
GRASS GIS trac at osgeo.org
Thu Dec 3 08:32:00 PST 2015
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  r.in.gdal, v.in.ogr, gui
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:26 martinl]:
 > Replying to [comment:25 mlennert]:
 > > Call it what you want. I actually like the idea of calling it a wizard
 as it simplifies a series of things, such as selecting layers in a file or
 in a database, that demand a more advanced knowledge to do directly in the
 modules.
 > try v.in.ogr dialog (--ui) in trunk, it allows you the same (except of
 importing several layers in the loop).
 Could you explain where this dialog comes from ? AFAIU, it is not the
 automatically created dialog based on the parser, or ? So even the --ui
 doesn't even give the normal interface anymore ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:27>
