[GRASS-dev] wingrass daily buidls + addons temporary down
Helmut Kudrnovsky hellik at web.de
Wed Dec 16 14:52:50 PST 2015
> But it's ready for testing!
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 67160
Build date: 2015-12-16
Build platform: x86_64-w64-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
tested with NC sample dataset:
(Wed Dec 16 22:36:18 2015)
r.slope.aspect elevation=elevation at PERMANENT slope=slope aspect=aspect
pcurvature=profcurv tcurvature=tangcurv dx=partderdx dy=partderdy
dxx=partderdxx dyy=partderdyy dxy=partdervdxy
Aspect raster map <aspect> complete
Slope raster map <slope> complete
Profile curve raster map <profcurv> complete
Tangential curve raster map <tangcurv> complete
E-W slope raster map <partderdx> complete
N-S slope raster map <partderdy> complete
Dxx raster map <partderdxx> complete
Dyy raster map <partderdyy> complete
Dxy raster map <partdervdxy> complete
(Wed Dec 16 22:36:26 2015) Command finished (8 sec)
(Wed Dec 16 22:38:52 2015)
r.watershed elevation=elevation at PERMANENT threshold=100
accumulation=accumulation tci=tci drainage=draindir basin=basinraster
stream=streamsegments half_basin=halfbasins length_slope=slopelengths
slope_steepness=slopesteepness
SECTION 1a (of 6): Initiating Memory.
SECTION 1b (of 6): Determining Offmap Flow.
SECTION 2: A* Search.
SECTION 3a: Accumulating Surface Flow with MFD.
SECTION 3b: Adjusting drainage directions.
SECTION 4: RUSLE LS and/or S factor determination.
SECTION 5: Watershed determination.
SECTION 6: Closing Maps.
(Wed Dec 16 22:39:31 2015) Command finished (38 sec)
(Wed Dec 16 22:41:04 2015)
r.stream.extract elevation=elevation at PERMANENT threshold=100
d8cut=10000000000000000000000000000000000000 stream_raster=runique
stream_vector=vuniqe direction=flowdir
Loading elevation raster map...
Initializing A* search...
A* Search...
Calculating flow accumulation...
Extracting streams...
Thinning stream segments...
Writing output raster maps...
Writing vector map <vuniqe>...
Writing attribute data...
Building topology for vector map <vuniqe at w64>...
Registering primitives...
15091 primitives registered
117778 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 7600
Number of primitives: 15091
Number of points: 7603
Number of lines: 7488
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
(Wed Dec 16 22:41:37 2015) Command finished (32 sec)
(Wed Dec 16 22:43:03 2015)
r.neighbors -c input=elevation at PERMANENT output=elevation_average_17 size=17
(Wed Dec 16 22:43:13 2015) Command finished (9 sec)
r.horizon elevation=elevation step=30 bufferzone=200 basename=horangle
maxdistance=5000
WARNING: Please update the usage of <r.horizon>: option <basename> has been
renamed to <output>
Calculating map 1 of 12 (angle 0.00, raster map <horangle_000>)
Calculating map 2 of 12 (angle 30.00, raster map <horangle_030>)
Calculating map 3 of 12 (angle 60.00, raster map <horangle_060>)
Calculating map 4 of 12 (angle 90.00, raster map <horangle_090>)
Calculating map 5 of 12 (angle 120.00, raster map <horangle_120>)
Calculating map 6 of 12 (angle 150.00, raster map <horangle_150>)
Calculating map 7 of 12 (angle 180.00, raster map <horangle_180>)
Calculating map 8 of 12 (angle 210.00, raster map <horangle_210>)
Calculating map 9 of 12 (angle 240.00, raster map <horangle_240>)
Calculating map 10 of 12 (angle 270.00, raster map <horangle_270>)
Calculating map 11 of 12 (angle 300.00, raster map <horangle_300>)
Calculating map 12 of 12 (angle 330.00, raster map <horangle_330>)
(Wed Dec 16 22:51:28 2015) Command finished (3 min 31 sec)
r.sun elevation=elevation horizon_basename=horangle horizon_step=30
aspect=aspect slope=slope glob_rad=global_rad day=180 time=14
Mode 1: instantaneous solar incidence angle & irradiance using a set local
time
Using Linke constant: 3.000000
Using albedo constant: 0.200000
Using slope map <slope>
Using aspect map <aspect>
(Wed Dec 16 22:54:20 2015) Command finished (11 sec)
(Wed Dec 16 23:02:04 2015)
r.sun elevation=elev_ned_30m linke_value=2.5 albedo_value=0.2 day=172
beam_rad=b172 diff_rad=d172 refl_rad=r172 insol_time=it172
Mode 2: integrated daily irradiation for a given day of the year
Using Linke constant: 2.500000
Using slope constant: 0.000000
Using aspect constant: 270.000000
(Wed Dec 16 23:54:16 2015) Command finished (52 min 11 sec)
(Wed Dec 16 23:55:27 2015)
r.topidx input=elevation at PERMANENT output=topidx
Reading elevation map...
Calculating...
Number of sinks or boundaries: 18679
Writing topographic index map...
(Wed Dec 16 23:55:32 2015) Command finished (4 sec)
after some quick tests of some ratser modules: it's quite responsive and
fast ...
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-daily-buidls-addons-temporary-down-tp5240948p5241683.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
