[GRASS-dev] [GRASS-SVN] r67282 - grass/trunk/lib/python/script
Vaclav Petras wenzeslaus at gmail.com
Mon Dec 21 13:22:07 PST 2015
On Mon, Dec 21, 2015 at 2:05 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> 2015-12-21 15:33 GMT+01:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > I think this is too risky. If I understand it correctly, it puts all the
> GUI
> > modules/packages on path. So, one will get:
> btw, there is similar issue in grass.py startup script [1]. Ma
> [1]
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L577
Yes. I think that the problem is little bit more likely to happen with
setup.init than for "GRASS scripts".
But perhaps we should remove it from there. There is a limited number of
places where some sort of GUI is started, so perhaps it should be done
manually everywhere as you already suggested for g.gui. modules.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151221/4401ace9/attachment.html>
