[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
GRASS GIS trac at osgeo.org
Tue Dec 22 01:12:40 PST 2015
  Reporter:  khe          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Database     |    Version:  7.0.2
Resolution:               |   Keywords:  v.in.ogr
       CPU:  Unspecified  |   Platform:  Linux
Changes (by martinl):
 * keywords:   => v.in.ogr
 * milestone:  Website => 7.0.3
Old description:
> Hey,
> I imported vector data by using the Python Shell
> g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_clip_strasse.shp",
> output=ort+"_strasse",overwrite=True, type="line",flags="o")
> g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_gewaesserordnung.shp",
> output=ort+"_gewaesser",overwrite=True, type="line",flags="o")
> g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_gewasserachse.shp",
> output=ort+"_gewaesserachse",overwrite=True, type="line",flags="o")
> g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_weg.shp",
> output=ort+"_weg",overwrite=True, type="line",flags="o")
> The database sqlite is connected (v.db.connect), I can open the vector
> layer, but cannot open the attribute table, but the command v.db.select
> works without having any problems.
> It says: "DMBI-SQLite driver error: Unable to scan data: Fehler: Kann
> Daten nicht aus der Tabelle <S_weg> holen.
> What could be the reason? Did anybody of you had similar problems?
> Thanks for your help.
New description:
 Hey,
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:2>
