[GRASS-dev] [GRASS GIS] #2824: g.gui.timeline throws exception when trying to display temporal dataset.
GRASS GIS trac at osgeo.org
Tue Dec 22 05:53:21 PST 2015
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  wxGUI        |    Version:  7.0.1
Resolution:               |   Keywords:  g.gui.timeline
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:6 neteler]:
 > Just tried trunk, with the original dataset:
 > Invalid input data
 > Reason: Space time dataset <tempmean> not found.
 > Traceback (most recent call last):
 >   File "/home/neteler/software/grass71/dist.x86_64-pc-linux-
 gnu/gui/wxpython/timeline/frame.py", line 444, in SetDatasets
 >     datasets = self._checkDatasets(datasets)
 gnu/gui/wxpython/timeline/frame.py", line 414, in _checkDatasets
 >     raise GException(errorMsg)
 > GException: Space time dataset <tempmean> not found.
 > Maybe a try - except could be still added for beautification.
 There is already try except, do you want to hide the traceback? But this
 is unrelated to the problem, is it working if you specify a correct
 dataset?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:7>
