[GRASS-dev] [GRASS GIS] #2300: v.out.ogr: spatialite support not working
GRASS GIS trac at osgeo.org
Wed Dec 23 05:34:03 PST 2015
  Reporter:  hamish    |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  7.0.3
 Component:  Vector    |    Version:  svn-trunk
Resolution:            |   Keywords:  v.out.ogr, spatialite
       CPU:  x86-64    |   Platform:  Linux
Comment (by mlennert):
 Replying to [comment:8 neteler]:
 > Replying to [comment:7 mlennert]:
 > > Did you apply Hamish' patch locally ?
 > No, I didn't.
 > > Or maybe a question of spatialite version ? I have 4.3.0. with SQLite
 version 3.9.2.
 > I use
 > [neteler at pgis_north grass70]$ rpm -qa | grep sqlite
 > sqlite-devel-3.9.0-1.fc23.x86_64
 > sqlite-3.9.0-1.fc23.x86_64
 > [neteler at pgis_north grass70]$ rpm -qa | grep spatialite
 > libspatialite-4.3.0a-1.fc23.x86_64
 > > The 'POINTZ' error is weird, as AFAIK POINTZ is a response to the
 specific shapefile driver option 'SHPT=type' and I don't know how this
 gets chosen for the SQLite format.
 > Maybe the wrong driver is picked up?
 But why ? And why with you and not for me ?
 I've just attached a patch that implements Hamish' solution for release70.
 With this I can export the points without error.
 But as Hamish mentioned, this is only a partial solution and the module
 probably needs similar fixes for other geometry types.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2300#comment:9>
