[GRASS-dev] [GRASS GIS] #2300: v.out.ogr: spatialite support not working
GRASS GIS trac at osgeo.org
Wed Dec 23 08:38:48 PST 2015
  Reporter:  hamish    |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  7.0.3
 Component:  Vector    |    Version:  svn-trunk
Resolution:            |   Keywords:  v.out.ogr, spatialite
       CPU:  x86-64    |   Platform:  Linux
Comment (by mlennert):
 Please try the new patch ( v_out_ogr_alltypes.patch) which covers points,
 lines and areas. With this patch applied, I can do each of the following
 which throws an error without the patch:
 v.out.ogr input=usgsgages output=usgsgages.sqlite format=SQLite type=point
 dsco='SPATIALITE=yes'
 v.out.ogr input=roadsmajor output=roadsmajor.sqlite format=SQLite
 type=line dsco='SPATIALITE=yes'
 v.out.ogr input=urbanarea output=urbanarea.sqlite format=SQLite type=area
 I also tested exporting each of these maps to shapefile.
 The patch was made with release70, but applies to trunk as well.
 I would appreciate some testing and a critical eye from someone a bit
 knowledgeable in OGR/v.out.ogr to make sure that this does not break
 anything in such an important module.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2300#comment:11>
