[GRASS-dev] [GRASS GIS] #2839: r.watershed: calculating stream power index crashes
GRASS GIS trac at osgeo.org
Tue Dec 29 12:06:34 PST 2015
  Reporter:  hellik  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.0.4
 Component:  Raster  |    Version:  svn-trunk
Resolution:          |   Keywords:  r.watershed
       CPU:  x86-64  |   Platform:  MSWindows 7
Comment (by hellik):
 Replying to [ticket:2839 hellik]:
 > tested with in the NC sample data set
 > System Info
 > GRASS version: 7.1.svn
 > GRASS SVN revision: 67403
 > Build date: 2015-12-29
 > Build platform: i386-w64-mingw32
 > GDAL: 1.11.3
 > PROJ.4: 4.9.2
 > GEOS: 3.5.0
 > SQLite: 3.7.17
 > Python: 2.7.4
 > wxPython: 2.8.12.1
 > Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 also tested with winGRASS 64bit
 Build platform: x86_64-w64-mingw32
 GDAL: 1.11.3
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.7.17
 Python: 2.7.5
 wxPython: 2.8.12.1
 r.watershed --verbose elevation=elevation at PERMANENT spi=spi_64bit
 SECTION 1a (of 4): Initiating Memory.
 SECTION 1b (of 4): Determining Offmap Flow.
 SECTION 2: A* Search.
 SECTION 3a: Accumulating Surface Flow with MFD.
 SECTION 3b: Adjusting drainage directions.
 WARNING: Unable to execute command
 WARNING: Subprocess failed with exit code -1073741819
 WARNING: category information for [spi_64bit] in [landsat] missing or
 invalid
 r.watershed also crashes here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839#comment:1>
