[GRASS-dev] results in winGRASS7 32bit vs 64bit: should they be identical?
Helmut Kudrnovsky hellik at web.de
Wed Dec 30 02:48:48 PST 2015
hi,
I've done some quick diff test with results of winGRASS7 32bit vs 64bit in
the NC sample dataset:
r.slope.aspect:
r.mapcalc aspect32bit - aspect64bit => 0
r.mapcalc slope32bit - slope64bit => 0
they seems to be identical.
r.watershed:
r.mapcalc accum32bit - accum64bit
r.info map=diffaccum at accumtest
 | Map:      diffaccum at accumtest            Date: Wed Dec 30 11:50:35 2015
 | Mapset:   accumtest                      Login of Creator: myricaria
 | DataBase: C:\grassdata
 | Title:     ( diffaccum )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    DCELL
 |   Rows:         1350
 |   Columns:      1500
 |   Total Cells:  2025000
 |        Projection: Lambert Conformal Conic
 |            N:     228500    S:     215000   Res:    10
 |            E:     645000    W:     630000   Res:    10
 |   Range of data:    min = -8.14907252788544e-010  max =
4.65661287307739e- |
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    accum32bit at accumtest - accum64bit at accumtest
the results between 32bit and 64bit winGRASS seems not to be identical.
any ideas if they should be identical?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/results-in-winGRASS7-32bit-vs-64bit-should-they-be-identical-tp5243280.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
