[GRASS-dev] [GRASS GIS] #906: r.out.gdal (VRT) broken output
GRASS GIS trac at osgeo.org
Wed Dec 30 05:11:34 PST 2015
  Reporter:  epifanio  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  6.4.6
 Component:  Raster    |    Version:  svn-develbranch6
Resolution:            |   Keywords:  r.out.gdal, VRT
       CPU:  x86-64    |   Platform:  MacOSX
Changes (by neteler):
 * milestone:  6.5.0 => 6.4.6
Old description:
> tring to generate a VRT file using r.out.gdal i get a broken file (not
> loadable in ossim and qgis)
> using gdal_translate i get a different results.
> using  r.out.gdal
> r.out.gdal input=geology at PERMANENT format=VRT type=Byte
> output=name.vrt
> output=name.vrt
> Exporting to GDAL data type: Byte
> Checking GDAl data type and nodata value
> Input raster map contains cells with NULL-value (no-data). The value 255
> will be used to represent no-data values in the input map. You can
> specify a nodata value with the nodata option.
> Exporting to GDAL raster
> ERROR 1: Writing through VRTSourcedRasterBand is not
> supported.
> Unable to write GDAL raster file
> Unable to export raster map <geology at PERMANENT>
> r.out.gdal complete.
> (Thu Feb  4 00:53:22 2010) Command finished (0 sec)
> i get this output :
> <VRTDataset rasterXSize="1899" rasterYSize="1398">
>   <SRS>PROJCS["UTM Zone 13, Northern
> Hemisphere",GEOGCS["clark66",DATUM["North_American_Datum_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["meter",1]]</SRS>
>   <GeoTransform>  5.9001000000000000e+05,  1.0000000000000000e+01,
> 0.0000000000000000e+00,  4.9280000000000000e+06,  0.0000000000000000e+00,
> -1.0000000000000000e+01</GeoTransform>
>   <VRTRasterBand dataType="Byte" band="1">
>     <NoDataValue>2.55000000000000E+02</NoDataValue>
>     <ColorInterp>Palette</ColorInterp>
>     <ColorTable>
>       <Entry c1="197" c2="129" c3="125" c4="255"/>
>       <Entry c1="107" c2="250" c3="75" c4="255"/>
>       <Entry c1="226" c2="83" c3="250" c4="255"/>
>       <Entry c1="246" c2="222" c3="188" c4="255"/>
>       <Entry c1="123" c2="225" c3="27" c4="255"/>
>       <Entry c1="134" c2="190" c3="1" c4="255"/>
>       <Entry c1="48" c2="86" c3="221" c4="255"/>
>       <Entry c1="113" c2="70" c3="15" c4="255"/>
>       <Entry c1="102" c2="134" c3="101" c4="255"/>
>       <Entry c1="89" c2="135" c3="169" c4="255"/>
>     </ColorTable>
>   </VRTRasterBand>
> </VRTDataset>
> this output is different from the gdal output :
> gdal_translate -of VRT
> /Users/sasha/Downloads/spearfish60/PERMANENT/cellhd/geology
> /Users/sasha/Desktop/geology.vrt
> <VRTDataset rasterXSize="190" rasterYSize="140">
>   <GeoTransform>  5.9000000000000000e+05,  1.0000000000000000e+02,
> -1.0000000000000000e+02</GeoTransform>
>   <Metadata/>
>     <Metadata>
>       <MDI key="COLOR_TABLE_RULES_COUNT">0</MDI>
>     </Metadata>
>     <NoDataValue>0.00000000000000E+00</NoDataValue>
>     <ColorTable>
>     </ColorTable>
>     <SimpleSource>
>       <SourceFilename
> relativeToVRT="0">/Users/sasha/Downloads/spearfish60/PERMANENT/cellhd/geology</SourceFilename>
>       <SourceBand>1</SourceBand>
>       <SourceProperties RasterXSize="190" RasterYSize="140"
> DataType="Byte" BlockXSize="190" BlockYSize="1"/>
>       <SrcRect xOff="0" yOff="0" xSize="190" ySize="140"/>
>       <DstRect xOff="0" yOff="0" xSize="190" ySize="140"/>
>     </SimpleSource>
>   </VRTRasterBand>
> </VRTDataset>
> the grass output doesn't include :
>     <SimpleSource>
>     </SimpleSource>
> it is missed and tring to load the output in ossim or qgis it is not
> displayed.
> from a chat on #gdal seems the problem is related to the "create_copy()"
> usage .. but i'm not able to debug it.
> thanks!
> Massimo.
New description:
 using  r.out.gdal
 r.out.gdal input=geology at PERMANENT format=VRT type=Byte output=name.vrt
 will be used to represent no-data values in the input map. You can specify
 supported.
 i get this output :
     <ColorTable>
     </ColorTable>
   </VRTRasterBand>
 </VRTDataset>
   <Metadata/>
     <Metadata>
     </Metadata>
     <ColorTable>
     </ColorTable>
     <SimpleSource>
       <SourceFilename
     </SimpleSource>
   </VRTRasterBand>
 </VRTDataset>
     <SimpleSource>
     </SimpleSource>
 displayed.
 thanks!
 Massimo.
Ticket URL: <https://trac.osgeo.org/grass/ticket/906#comment:3>
