[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
GRASS GIS trac at osgeo.org
Fri Feb 13 06:39:57 PST 2015
 Reporter:  marisn                                                           |       Owner:  grass-dev@…
     Type:  defect                                                           |      Status:  new
 Priority:  blocker                                                          |   Milestone:  7.0.0
Component:  wxGUI                                                            |     Version:  svn-trunk
 Keywords:  security, code injection, SQL injection, data loss, v.db.update  |    Platform:  Unspecified
      Cpu:  Unspecified                                                      |
Comment(by mlennert):
 Replying to [comment:5 marisn]:
 > Replying to [comment:4 mlennert]:
 > > I can't reproduce this bug. I've tried with different SQL texts and
 they all are just put into the text field in the attribute table.
 > > Maris, can you still confirm this bug ?
 > Nothing has changed. Still text fields fail if a single apostrophe is
 entered. Deleting whole database via text attribute entry field has been
 left as an excise for reader ;)
 Ok, I forgot the apostrophes.
 However, I tried deleting a table and haven't been able to do so:
 db.execute sql="CREATE TABLE test_db_bug (id int)"
 v.db.update test_digit_new col=test_text val="';drop table test_db_bug;'"
 Table test_db_bug is still in the database. Same when I put the same value
 in a text field in the digitizer: I get a similar error message to yours
 above, but the table is not dropped.
 Apparently any apostrophe in the update value causes an error message. I
 agree that the error message is not clear, but I cannot reproduce the
 danger you see for database integrity.
 So my question remains, is this really a blocker ?
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2252#comment:6>
