[GRASS-dev] [GRASS-user] can not install addons with g.extension
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat Feb 14 00:39:08 PST 2015
On 02/14/2015 09:32 AM, Martin Landa wrote:
> 2015-02-14 9:21 GMT+01:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>> https://www.debian.org/doc/debian-policy/ch-files.html#s-scripts
>> It is a "should" requirement, so it's not a hard requirement. We had to
>> reinstate .py extention for GDAL scripts because it broke the QGIS
>> plugin for example.
> this is similar case, I am not sure what is better, to break Debian
> rule or to change a rule in Grass.make... ?
Since the script in question is not in $PATH it's safe to ignore the
Policy for it.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
