[GRASS-dev] [GRASS GIS] #2534: i.segment.hierarchical install error
Javier Martínez-López javi.martinez.lopez at gmail.com
Sun Feb 15 12:23:35 PST 2015
Thank you Markus! Cheers, Javier
On Sat, Feb 14, 2015 at 12:36 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Feb 13, 2015 at 7:44 PM, Javier Martínez-López
> <javi.martinez.lopez at gmail.com> wrote:
>> I have the same issue in GRASS 7.1 revision: 63930 under Fedora linux
>> 21, is it possible to go around this problem?
> Sure (I'm also on Fedora) but this is vali for any Linux distro
> you need to specify where your GRASS GIS sources are:
> e.g.:
> make MODULE_TOPDIR=$HOME/software/grass71
> then it compiles fine.
> Markus
