[GRASS-dev] [GRASS-SVN] r64649 - in grass-addons/grass7/raster/r.green: . r.green.biomassfor/r.green.biomassfor.economic r.green.biomassfor/r.green.biomassfor.impact r.green.biomassfor/r.green.biomassfor.legal r.green.biomassfor/r.green.biomassfor.recommended r.green.biomassfor/r.green.biomassfor.technical r.green.biomassfor/r.green.biomassfor.theoretical
Pietro peter.zamb at gmail.com
Mon Feb 16 08:23:39 PST 2015
Hi Martin,
On Mon, Feb 16, 2015 at 3:20 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-02-16 14:36 GMT+01:00  <svn_grass at osgeo.org>:
>> Author: zarch
>> Date: 2015-02-16 05:36:51 -0800 (Mon, 16 Feb 2015)
>> New Revision: 64649
>> Modified:
>>    grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.economic/Makefile
> why so much nested? The right naming should be
> grass-addons/grass7/raster/r.green/r.green.biomassfor/Makefile
because thee are several modules going on (but not yet published, they
are under testing) for other different sources (r.green.hydro,
r.green.wind, r.green.solar), that are following the same structures
and have shared libraries between them.
I'm open to suggestions, here it is a complete list of modules:
r.gree/
├── AUTHORS.txt
├── biblio
│   └── 1-s2.0-S016761051300007X-main.pdf
├── libgreen
│   ├── checkparameter.py
│   ├── checkparameter.pyc
│   ├── __init__.py
│   ├── __init__.pyc
│   ├── Makefile
│   ├── utils.py
│   └── utils.pyc
├── LICENSE.txt
├── Makefile
├── README.txt
├── r.green.biomassfor
│   ├── Makefile
│   ├── r.green.biomassfor.economic
│   ├── r.green.biomassfor.html
│   ├── r.green.biomassfor.impact
│   ├── r.green.biomassfor.legal
│   ├── r.green.biomassfor.recommended
│   ├── r.green.biomassfor.technical
│   └── r.green.biomassfor.theoretical
├── r.green.html
├── r.green.hydro
│   ├── libhydro
│   ├── Makefile
│   ├── r.green.hydro.closest
│   ├── r.green.hydro.delplants
│   ├── r.green.hydro.discharge
│   ├── r.green.hydro.economic
│   ├── r.green.hydro.html
│   ├── r.green.hydro.legal
│   ├── r.green.hydro.optimal
│   ├── r.green.hydro.recommended
│   ├── r.green.hydro.structure
│   ├── r.green.hydro.technical
│   └── r.green.hydro.theoretical
├── r.green.solar
│   ├── Makefile
│   ├── r.green.solar.economic
│   ├── r.green.solar.html
│   ├── r.green.solar.theoretical
│   ├── r.green.solar.recommended
│   └── r.green.solar.technical
├── r.green.TEV
│   └── r.green.TEV.py
└── r.green.wind
    ├── Makefile
    ├── r.green.wind.economic
    ├── r.green.wind.html
    ├── r.green.wind.theoretical
    ├── r.green.wind.recommended
    └── r.green.wind.technical
34 directories, 22 files
Any better ideas?
