[GRASS-dev] RPC and lib/python/temporal/testsuite/test_doctests.py on MS Windows
Vaclav Petras wenzeslaus at gmail.com
Mon Feb 16 11:01:19 PST 2015
Hi all,
when running the tests on MS Windows doctest for grass.temporal does not
continue when fatal error was issued by libgis server. stderr ends with:
    C:\...\grass_trunk_r64651\lib\python\temporal\testsuite>python
test_doctests.py
    ........Default TGIS driver / database set to:
    driver: sqlite
    database:
C:\Users\vpetras\Documents\grassdata/demolocation/PERMANENT/tgis/sqlite.db
    Creating temporal database:
......................................F..............................FF....FFFF
    ERROR: Fatal Error in C library server
There are some failed tests but that's most likely unrelated, the problem
is that the process is still running but giving no further output. This
probably means that any temporal module which will cause fatal error with
hang like this.
After pressing Ctrl+C I get:
    WARNING:root:Needed to restart the libgis server
but the process does not end and I had to press Ctrl+C several times (and
got the warning several times) to actually end the process.
On Ubuntu there are no failed tests but more importantly, the libgis server
is restarted as expected and the test ends successfully:
    driver: sqlite
    database:
/grassdata/tests-grassdata/nc_spm_08_grass7/__lib_python_temporal_test_doctests/tgis/sqlite.db
Do you have any idea why it gets stuck when the RPC server exits?
Vaclav
### How to test this on MS Windows
Install the latest build of trunk for Windows. Get the latest source code:
If you don't have Subversion on Windows, checkout the latest version on
Linux (or make distclean && svn up), zip it and unzip it on Windows. Run
GRASS (cmd line is enough). Cd into the source code, into the
lib\python\temporal\testsuite directory and run:
    python test_doctests.py
Alternatively, cd into the source code dir and run all tests as usually (
http://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html
    python -m grass.gunittest.main --location nc_spm_08_grass7
--location-type nc
This of course applies if you are not compiling yourself, if you do, you
have corresponding binary and source code on you computer.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150216/efdf10cf/attachment.html>
