[GRASS-dev] [GRASS GIS] #1819: problems compiling map swipe, animation, modeler, and r.li.setup
GRASS GIS trac at osgeo.org
Tue Feb 17 15:23:02 PST 2015
 Reporter:  cmbarton         |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  g.gui.* modules  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
Comment(by wenzeslaus):
 Replying to [comment:10 cmbarton]:
 > This solved all the compiler errors except for g.gui.tplot
 I simply forgot to change `g.gui.tplot` because I was looking at the list
 in comment:7:ticket:2561. Fixed in r64674.
 >  and the failure to make the menu tree xml files.
 Replying to [comment:11 cmbarton]:
 > Because of the failure for some Python code to create the menu tree
 files during compilation, I have to launch a GRASS session, cd to the
 ../gui/wxpython directory, make clean, and make. This also 'fixed' the
 errors in animation, map swipe, etc.
 That's the part which should be fixed once #2142 is fixed. Unfortunately,
 I'm not able to fix it for the 7.0.0 release. It requires a lot of design
 decisions and testing.
 And as I said, these changes make sense in general but basically they are
 all workarounds. The actual issue is wrong runtime environment during
 compilation where 64 and 32 bit libraries are mixed.
 This ticket should be closed once r64664 and r64674 are backported to
 release branch 7.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1819#comment:12>
