[GRASS-dev] winGRASS 64bit
Fri Feb 27 18:22:56 PST 2015
Martin Landa wrote:
> > 2015-02-26 1:40 GMT+01:00 Glynn Clements <glynn at gclements.plus.com>:
> >> "undefined reference to __imp_xxxx" usually means that it found the
> >> import library but not the corresponding DLL.
> > right, it seems to be this case. Thanks for hint, Martin
> regex-devel contains just a static library. Is it possible to solve
> compilation issue somehow or do I need DLL lib?
If they're following the same naming conventions as Linux
distributions, there should be a corresponding "regex" package
containing the DLL.
Running software which uses the regex functions would only need the
"regex" package, while compiling it would need both the "regex" and
"regex-devel" packages.
