[GRASS-dev] Is grass70b4 compiling on FreeBSD ?
Fábio Dias fabio.dias at gmail.com
Thu Jan 8 19:14:34 PST 2015
Full installation log, fresh system:
http://pastebin.com/ARDd1HQv
/usr/include/iconv.h
http://pastebin.com/yf6ycz66
/usr/local/include/iconv.h (installed by cairo afaik)
http://pastebin.com/7BMNAMYA
gmake on lib/gis
http://pastebin.com/PAgAfnfh
As far as I understood, not all things iconv are implemented in the
system version.
Fábio Augusto Salve Dias
http://sites.google.com/site/fabiodias/
On Wed, Jan 7, 2015 at 2:35 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Fábio Dias wrote:
>> The files /usr/include/iconv.h and /usr/local/include/iconv.h are different.
> Does /usr/include/iconv.h contain the macros?
>         #define iconv_open libiconv_open
>         #define iconv libiconv
>         #define iconv_close libiconv_close
> If not, it looks like it's now picking up some other iconv.h.
> According to this:
> https://www.freebsd.org/doc/en/books/porters-handbook/using-iconv.html
> FreeBSD 10-CURRENT and later has iconv in libc, so no additional
> libraries should be linked. But that will require the use of the
> system iconv.h rather than a libiconv iconv.h.
>> I removed the local one, re-run ./configure (both iconv related
>> messages: yes) and gmake. Same deal. No -liconv included on
>> include/Make/Platform.make, same error when linking.
>> I also removed the --with-includedir=local and added iconv.h from another dir:
>> /configure --with-includes=~/  --with-postgres --with-pthread
>> --with-gdal --with-includes=/usr/local/include
>> --with-libs=/usr/local/lib
>> --with-freetype-includes=/usr/local/include/freetype2 --with-readline
>> --with-geos --with-wxwidgets --with-lapack --with-sqlite
>> Same deal. It says yes for both iconv tests and doesn't link it.
> Can you show the actual compilation commands being used, specifically
> for parser_interface.c in lib/gis (that's where the lib/gis -> iconv
> dependency comes from; lib/driver and lib/cairodriver also have iconv
> dependencies)?
