[GRASS-dev] Tests down to 78% (from 84%), mostly PyGRASS
Vaclav Petras wenzeslaus at gmail.com
Fri Jan 9 07:01:20 PST 2015
On Mon, Jan 5, 2015 at 4:15 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2015-01-05 21:21 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> > No problem. The only remaining thing which I don't understand how to
> > fix it is this:
> >   File "./lib/gis/testsuite/gis_lib_env_test.py", line 31, in test_gisrc
> >     libgis.G__read_gisrc_env()
> > AttributeError: 'module' object has no attribute 'G__read_gisrc_env'
> done in r63960 (and backported). Martin
On Wed, Jan 7, 2015 at 10:37 AM, Pietro <peter.zamb at gmail.com> wrote:
> Il 07/gen/2015 16:11 "Vaclav Petras"  wrote:
> > Thanks but the tests are failing with different error now:
> > Traceback (most recent call last):
> >   File "lib/python/pygrass/raster/testsuite/test_raster.py", line 6, in
> <module>
> >     from grass.pygrass.raster import RasterRow
> >   File "etc/python/grass/pygrass/raster/__init__.py", line 24, in
> <module>
> >    from grass.pygrass.gis.region import Region
> >   File "etc/python/grass/pygrass/gis/__init__.py", line 22, in <module>
> >     'icon': libgis.G_ELEMENT_ICON,
> > AttributeError: 'module' object has no attribute 'G_ELEMENT_ICON'
> I saw the error this morning. Should be fixed in r63972.
> Pietro
To see if the tests are successful before you commit anything use inside
GRASS session:
python -m grass.gunittest.main --location nc_spm_grass7 --location-type nc
where "nc_spm_grass7" is your GRASS GIS sample NC SPM location. Read more
about running tests here:
http://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html#testing-with-gunittest-package-in-general
I went through the tests and there is still several issues (ignoring the
once caused by different maps in NC full and basic):
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/test_doctests/index.html
NameError: name 'Region' is not defined
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/raster/test_history/index.html
OpenError: The map does not exist, I can't open in 'r' mode
(probably missing map but the error message should be better)
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/modules/test_doctests/index.html
AttributeError: 'module' object has no attribute 'grid'
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/shell/test_doctests/index.html
AttributeError: 'module' object has no attribute 'conversion'
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/gis/test_doctests/index.html
AttributeError: 'module' object has no attribute 'region'
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.rast3/test_strds_to_rast3/index.html
RuntimeError: Module call r3.univar(...) ended successfully but we were
expecting output and got nothing. There were no error messages.
(see #2269, http://trac.osgeo.org/grass/ticket/2269)
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-09-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.accumulate/test.t.rast.accumulate/index.html
(hard to tell, it is an bash script)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150109/b0e9de12/attachment.html>
