[GRASS-dev] svn merge usage
Vaclav Petras wenzeslaus at gmail.com
Sat Jan 31 16:50:04 PST 2015
I just did backport of r64270 and used
svn propdel svn:mergeinfo .
and I again deleted some merge infos although I deleted them (all) last
time. So, am I supposed to use `svn propdel` or not?
http://trac.osgeo.org/grass/changeset/64380
On Thu, Jan 15, 2015 at 10:37 AM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Thu, Jan 15, 2015 at 2:36 AM, Glynn Clements <glynn at gclements.plus.com>
> wrote:
>> > This deletes all mergeinfos, so you got a large diff when you executed.
>> > You are saying that this is ok, i.e. we want to get rid of the infos?
>> Deleting the svn:mergeinfo property is probably safe, as we're
>> unlikely to ever merge entire branches.
> On Thu, Jan 15, 2015 at 8:33 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Backported in r64193 (along with "svn propdel svn:mergeinfo ." to see
>> how it behaves).
> It deletes all mergeinfos, so we got a large diff now [1], Trac shows it
> in siple way [2]. However, next time it will remain deleted as long as we
> use `propdel`, so no large diffs will be happening and everything will be
> fine.
> To paraphrase one of Git design rules [3]: If SVN offers some feature, be
> sure not to use it.
> Vaclav
> [1] http://lists.osgeo.org/pipermail/grass-commit/2015-January/035099.html
> [2] http://trac.osgeo.org/grass/changeset/64193g
> [3]
> http://en.wikipedia.org/w/index.php?title=Git_%28software%29&oldid=641271361#History
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150131/bcea1ca7/attachment.html>
