[GRASS-dev] what is the meaning of: "Error reading raster data for row 239 of <MASK>"
Moritz Lennert mlennert at club.worldonline.be
Wed Jul 15 09:11:03 PDT 2015
On 15/07/15 05:21, Glynn Clements wrote:
> Moritz Lennert wrote:
>> So, for me, the best solution at this stage is to just set WORKERS
>> to 0 ?
> That should work. Also, the issue should be fixed by r65591.
Seems to work nicely. Thanks for the quick fix !
One thing I noticed is that on the one test case I used here for
testing your fix, running with WORKERS=0 is slightly faster than without
setting it. I didn't test rigorously, but is that expected ?
Moritz
