[GRASS-dev] Fwd: New section in GRASS wiki for installation under Mac using homebrew
Carlos Grohmann carlos.grohmann at gmail.com
Fri Jul 31 14:22:53 PDT 2015
Hi
The homebrew formula doesn't really work on OSX 10.11 beta. In the log file
(link below) I can see the same errors in compilation I got when tried to
compile svn. They are related to html manual pages, but prevent
installation from continue.
Carlos
log files:
https://www.dropbox.com/s/ufvw198bix7t7xj/02.make?dl=0
https://www.dropbox.com/s/1ij9c5havtjczk1/config.log?dl=0
brew tap rkrug/head-only
==> Tapping rkrug/head-only
Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
remote: Counting objects: 4, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
Unpacking objects: 100% (4/4), done.
Checking connectivity... done.
Tapped 1 formula (27 files, 116K)
brew install grass-71
Error: rkrug/head-only/grass-71 is a head-only formula
Install with `brew install --HEAD rkrug/head-only/grass-71`
Warning: You are using OS X 10.11.
We do not provide support for this pre-release version.
You may encounter build failures or other breakage.
==> Installing grass-71 from rkrug/homebrew-head-only
Error: No available formula for nc_spm_08_grass7 (dependency of
rkrug/head-only/grass-71)
guano$ brew install --HEAD rkrug/head-only/grass-71
--without-nc_spm_08_grass7
==> Cloning https://svn.osgeo.org/grass/grass/trunk
Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
==> Patching
patching file include/Make/Install.make
Hunk #1 succeeded at 116 (offset 2 lines).
==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
--with-
==> make GDAL_DYNAMIC=
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Jul 31 17:36:12 BRT 2015
make: *** [default] Error 1
READ THIS: https://git.io/brew-troubleshooting
If reporting this issue please do so at (not Homebrew/homebrew):
  https://github.com/rkrug/homebrew-head-only/issues
GuanoAFBIOTA:~ guano$
On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <carlos.grohmann at gmail.com
> wrote:
> Very interesting!
> From the brew recipe, it looks that one needs all dependencies installed
> via homebrew, is that right? I'm thinking that most will have Kyngsburie's
> Frameworks already installed (at least GDAL). Same goes for wx-python.
> best
> Carlos
> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Anna Petrášová <kratochanna at gmail.com> writes:
>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> >> Hi
>> >> I just added a section / new page in the WIKI for installation of GRASS
>> >> using homebrew. Please see
>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
>> >> and
>> >> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
>> >> It would be great if some Mac / homebrew users would see if it works
>> and
>> >> give me comments here.
>> > I will try to test it next week. Thank you for your efforts!
>> Great - let me know how it goes, although I don't know if I will be able
>> to reply as I am away and possibly only have very limited internet
>> access.
>> Thanks,
>> Rainer
>> > Anna
>> >> Cheers,
>> >> Rainer
>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> >> Biology, UCT), Dipl. Phys. (Germany)
>> >> Centre of Excellence for Invasion Biology
>> >> Stellenbosch University
>> >> South Africa
>> >> Tel :       +33 - (0)9 53 10 27 44
>> >> Cell:       +33 - (0)6 85 62 59 98
>> >> Fax :       +33 - (0)9 58 10 27 44
>> >> Fax (D):    +49 - (0)3 21 21 25 22 44
>> >> email:      Rainer at krugs.de
>> >> Skype:      RMkrug
>> >> PGP: 0x0F52F982
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> South Africa
>> Skype:      RMkrug
>> PGP: 0x0F52F982
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
________________
________________
________________
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150731/57365a26/attachment.html>
