[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Wed Jun 10 14:20:10 PDT 2015
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.1
 Component:  Display      |    Version:  7.0.0
Resolution:               |   Keywords:  font, text, legend, scale bar
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by hellik):
 Replying to [comment:16 wenzeslaus]:
 > Replying to [comment:14 wenzeslaus]:
 > > Replying to [comment:13 hellik]:
 > > > Replying to [comment:12 annakrat]:
 > > > > I made a screencast to see what's in the terminal which just
 flashes during the installation. I get:
 > > ERROR: GISRC - variable not set
 > > > > This is the same what happens if you run run_gmkfontcap from
 windows command prompt.
 > > > relevant lines of codes
 [http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
 Installer.nsi.tmpl#L531 g.mkfontcap] and following.
 > > 546         FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
 > > 547         FileWrite $0 '$\r$\n'
 > > 548         FileWrite $0 'rem set path to freetype dll$\r$\n'
 > > 549         FileWrite $0 'set
 FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
 > > 550         FileWrite $0 '$\r$\n'
 > > 551         FileWrite $0 'rem set dependecies path$\r$\n'
 > > 552         FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
 > > > any idea which variable isn't set?
 > > It is the [http://grass.osgeo.org/grass70/manuals/variables.html#list-
 of-selected-%28grass-related%29-shell-environment-variables GISRC]
 variable which is not set.
 > > We could perhaps avoid this problem altogether if we would just tell
 GRASS GIS what to run (#2579),
 > After r65252 and r65294 (see #2579) you can use (in trunk, upcoming 7.1
 release):
 > C:\path\to\grass C:\path\to\demomapset --exec g.mkfontcap
 > This should run `g.mkfontcap` in a regular GRASS session but without
 touching user's GRASS rc file in home directory (if it does, it's a bug),
 so the last used Mapset will be still whatever user or installer sets.
 > > although this might have its own problems during installation.
 > GRASS is installed, right? So this should work in theory.
 > > One other thing is that it is not clear to me what changed that now
 GISRC variable is required but it was not before.
 > Let's say that we don't need to deal with this because it is expected
 that GRASS module requires `GISRC` to be set. I'm just not sure why it is
 expected by `​g.mkfontcap` (probably it calls some GRASS library
 functions).
 the discussion about a g.mkfontcap outside a winGRASS session dates back
 to 2010.
 I've found following in this long discussion:
 http://lists.osgeo.org/pipermail/grass-dev/2010-March/049491.html
 On Sat, 6 Mar 2010, Helmut Kudrnovsky wrote:
 > from the grass-windows-point-of-view:
 > I've tested in the last days a lot the issues in
 > http://trac.osgeo.org/grass/ticket/908
 > r40857 (see http://trac.osgeo.org/grass/ticket/908#comment:9) should be
 > backported to grass64. g.mkfontcap with this fixes is working outside a
 > grass-session.
 Just to note, the Linux install script (binaryInstall.src) runs
 g.mkfontcap outside of a GRASS session by simply setting GISRC to a junk
 value:
 GISBASE="$DESTDIR" GISRC=junk
 LD_LIBRARY_PATH_VAR="${DESTDIR}/lib:$LD_LIBRARY_PATH_VAR"
 "${DESTDIR}/bin/g.mkfontcap" -o
 (In Windows the equivalent would be to run the command
 set GISRC=junk
 before running g.mkfontcap)
 Not 100% sure if that's relevant here, but thought it might be worth
 mentioning to give some context.
 Paul
 should we try this solution in winGRASS7.x-series?
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:17>
