[GRASS-dev] [GRASS GIS] #2694: rendering command layer and adding 3d raster layer broken
GRASS GIS trac at osgeo.org
Fri Jun 12 13:24:54 PDT 2015
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  rendering
       CPU:  Unspecified  |   Platform:  Linux
Comment (by martinl):
 Replying to [ticket:2694 annakrat]:
 > 1. adding 3D raster layer breaks rendering, although there is no error,
 rendering just stops working after that and busy cursors stays there. I
 was trying to fix this one, but was not able to get rid of the progress
 bar which was still showing up:
 please try out r65450
 > 2. Rendering command layers is weird, (un)checking has no effect.
 I would suggest to remove command layers from wxGUI completely, what do
 you think?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:1>
