[GRASS-dev] All Python addons are missing
Vaclav Petras wenzeslaus at gmail.com
Sun Jun 14 03:30:32 PDT 2015
On Sun, Jun 14, 2015 at 4:49 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2015-06-14 1:56 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > http://grass.osgeo.org/addons/grass7/logs/d.vect.thematic2.log
> btw, I am getting strange error on server when compiling relbr70:
> GRASS GIS 7.0.1svn r65457 compilation log
> Started compilation: Sun Jun 14 10:16:48 CEST 2015
> Errors in:
> /opt/src/grass70_release/lib/python/gunittest
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Sun Jun 14 10:16:57 CEST 2015
> make: *** [default] Error 1
> but this directory doesn't exist
> cd lib/python/gunittest
> -bash: cd: lib/python/gunittest: No such file or directory
The build for gunittest dir was requested in the Makefile. This was caused
by accidental backport in r65439. Pietro, svn st and svn diff are your
friends :)
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/lib/python/Makefile?annotate=blame&rev=65439
https://trac.osgeo.org/grass/changeset/65439
https://trac.osgeo.org/grass/changeset/65461
Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150614/c11c38ee/attachment-0001.html>
