[GRASS-dev] [GRASS GIS] #2692: v.in.ascii does not handle text in qoutes
GRASS GIS trac at osgeo.org
Wed Jun 17 03:16:33 PDT 2015
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.0.1
 Component:  Default     |    Version:  svn-trunk
Resolution:              |   Keywords:  CSV, doublequote, singlequote, text
       CPU:              |  delimiter
  Unspecified            |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:3 glynn]:
 > Replying to [comment:2 mlennert]:
 > > The attached patch seems to solve the problem for me, but it feels
 like a quick fix and there probably is a better way...
 > Simply removing the quotes isn't sufficient to support CSV. It's
 necessary to treat the field separator as a normal character when it
 occurs within a quoted field (that's the point of using quotes), and also
 to replace two consecutive quotes with a single quote (so that the quote
 character itself can occur within a field).
 > For that, an explicit state machine is likely to be more legible than
 ad-hoc logic.
 Sounds like a fun programming challenge (for it's a challenge at least),
 but I wonder whether we couldn't just integrate the work of others in the
 same domain, notably [http://sourceforge.net/projects/libcsv/ libcsv].
 It's GPL (2 or higher) and its fairly lightweight, so we could just
 integrate it into the GRASS source (although Debian ships it as a package
 as well, don't know for other distributions, nor for OSX and Windows).
 AFAICS, there have been no modifications since 2013, so it does not look
 like a heavy dependency to track.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2692#comment:4>
