[GRASS-dev] [GRASS GIS] #2699: g.gui.iclass doesn't run after selecting training areas
GRASS GIS trac at osgeo.org
Sat Jun 20 14:53:44 PDT 2015
  Reporter:  ThayseNery  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  major       |  Milestone:  7.0.1
 Component:  wxGUI       |    Version:  7.0.0
Resolution:              |   Keywords:  g.gui.iclass, digitizer
       CPU:  x86-64      |   Platform:  MSWindows 7
Changes (by annakrat):
 * keywords:  g.gui.iclass => g.gui.iclass, digitizer
Comment:
 Issues reported in the ticket description should be fixed in r65506, will
 be backported once tested. The export of training areas is fixed as well.
 '''Remaining problems'''
 This happens when g.gui.iclass window is opened, even on Linux:
 G__open(read): Unable to open 'C:\Users\akratoc\grassdata/nc
 _spm_08_grass7/user1/.tmp/unknown/vector/trAreas64800/frmt':
 No such file or directory
 This happens only on Windows when trying to import previously saved
 training areas:
   File "C:\Program Files (x86)\GRASS GIS
 7.1.svn\gui\wxpython\iclass\frame.py", line 538, in
 OnImportAreas
 self.ImportAreas(vName)
 7.1.svn\gui\wxpython\iclass\frame.py", line 595, in
 ImportAreas
 self.poMapInfo = digitClass.OpenMap(vname, tmp = True)
 7.1.svn\gui\wxpython\vdigit\wxdigit.py", line 1649, in
 OpenMap
 self.poMapInfo = self._display.OpenMap(str(name),
 str(mapset), update, tmp)
 7.1.svn\gui\wxpython\vdigit\wxdisplay.py", line 962, in
 OpenMap
 Vect_set_updated(self.poMapInfo, True) # track updated lines
 at update mode
 WindowsError
 exception: access violation reading 0x000002E4
 I would appreciate some help with this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2699#comment:5>
