[GRASS-dev] temporal modules cannot open database
Luca Delucchi lucadeluge at gmail.com
Thu Jun 25 02:30:10 PDT 2015
On 25 June 2015 at 00:05, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hio Soeren
> is it possible that the path to the location has changed or that the
> location was renamed?
mmm I don't think so, but I'm not sure.
The path to db it seems correct using t.connect -l, do you have any
trick to solve this problem?
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
