[GRASS-dev] temporal modules cannot open database
Luca Delucchi lucadeluge at gmail.com
Fri Jun 26 02:10:37 PDT 2015
On 25 June 2015 at 11:53, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren,
> i just committed a patch in SVN that can handle modified location path's.
> Please make an update of grass7.1 and then call t.connect -d in the
> specific location/mapset to reset the default connection, which is
> mapset specific.
> I hope the temporal framework will find the correct database again.
yes now it works!
> Best regards
> Soeren
Thanks a lot
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
